Will this fit? (Dark Pro 3)
14 Jan 2014
Hello all, I'm do a platform+case change. I'm currently on 4690K/8GB ram/GTX 1080/Corsair 350D. I'm ordering a 8700K/16GB Trident Z RGB (already have) and Phanteks Evolv ATX.
Just to check, would a Dark Rock Pro 3 fit with this setup? If not I'll just grab the regular non-pro variant.
Thanks in advance :)
Their page states can take coolers 190m tall so should be good, even if you need to raise fan a bit to allow 4 ram sticks to fit in
Damn good cooler, still on deal is it ?
You'll find that you can make a more aggressive CPU fan curve then default too :)
Hadn't checked if it was on a deal or not. Just worried about the ram, even though I'm only using 2 sticks haha! Thanks for the reply :)
