GPU/CPU Cooling Issues Air Cooler + GPU Cooler
1 Aug 2010
Hi guys. I'm rocking a 1080TI sea hawk x which is an AIO cooler card.
I'm also running a Noctua D15S.
These are both currently exhausting out of the back of my case whilst two 140mm noctua fans are in taking at the front.
My GPU temperatures are getting quite toasty due to the fast the CPU is push air through the GPU rad. What is the best to have my setup please? Or am i best to get an AIO cpu cooler to blow out the top of the case please?
give your seahawk to me? that would solve the thermal issue quickly :D
proper answer: not quite sure, but you definitely don't want to be intaking air with the aio. dumping 280w of heat into the case isn't good for cpu temps either lol
The aio on the graphics card will be pumping out a lot of hot air. You want that to be going out. If it's a thick rad consider push pull for it. My cpu aio pulls air in from the front while my gpu exhausts it at the top. I have a rear fan pushing a bit of air in and a lower front one too. Gpu 40-45 cpu not above 50 while gaming. Fan rpm about 800 on both
