Upgrade help?
23 Dec 2008
Plymouth
Hi Guys,
Not been active within the PC community for literally years due to family and work etc.
So i am really out of touch with current components and was wondering if i could possibly have some help please!
Not wanting to spend a fortune but would like something half decent.
What i can salvage off my current PC -
Case
HDD
Optical Drives
I have 8GB of DDR3 1600mhz but im guessing that may be outdated now?
I dont need an OS or any peripherals.
Any suggestions would be fantastic! Thanks in advance
Me7Jc
This is my current spec, in case anything else can be salvaged
Thanks for that, i sort of chucked a list together using common sense, will the PSU be enough for the GPU?
My basket at Overclockers UK:
Total: £471.05 (includes shipping: £11.10)​
Yes i do think the power supply would be enough.
You have a decent spec for the money there.
I picked seasonic due to their psu being higher quality.
edit you will be able to play games on high/max @ 1080p with that gpu.
Pick up a second hand i7 and drop it in your current motherboard along with another matching 8 Gb stick of memory. If it's for gaming pick up a decent gpu as well.
I think the ryzen ipc is like the same with intels 4xxx series correct me if i am wrong.
Yeah get a 2nd hand i7 4 series processor, if your motherboard supports it go for it.
The reason why i went with ryzen in the first place knowing this is because of ryzens value for the performance a ryzen 1600 would stomp a 7600k for instance.
But coffee lake is now out which is the 8xxx series of intels lineup.
edit.
So yeah your motherboard supports the i7 4xxx series processor i wonder if you need to update the bios or not yeah?
https://www.gigabyte.com/Motherboard/GA-B85-HD3-rev-1x#sp
