I’m in this hobby on a tight budget generally as I have plenty of other expensive ones to suck my money away lol. Therefore my current rig I’ve just (re)built roughly resembles a top of the line one from 3-4 years ago. One thing I am into is overclocking but the coolers I have are holding me back.
Now I do have a Corsair H60 for the CPU which is really good for what it is but won’t let me go much higher on voltages than I am now without hitting the 90C mark under full load. The GPU is a reference 780 ti so gets pretty toasty and loud even at stock speeds.
Bearing those two factors in mind I have had 2 ideas for cooling - first one is to upgrade the CPU cooler to a 240mm AIO and fit the H60 to the GPU using the bracket.
Second idea is to pick up a low cost water cooling kit for both CPU and GPU a la the “Glowry” kit available from a well known online retailer
With the first option I would obviously need space for 2 rads which would be a squeeze could be done, and I’m at the mercy of Corsair (or someone) to bring out a new bracket for whatever GPU I upgrade to in the future
Second option would hopefully see me set up with a reasonable loop and 1 rad and would be neater but the very low cost kind of casts doubt in my mind about the quality of the parts? But then again what is there to go wrong more so than a £50 AIO cooler like a Coolermaster Seidon?
Third option is just to get a 240mm AIO for the CPU and get a better air cooler for the GPU but that doesn’t seem worth it on a £100 card if I can’t transfer it when I upgrade it
