I’m currently running a cheap pair of Logitech 2.0 speakers via on-board sound (I believe it’s an ALC1150 chipset). I am upgrading the speakers to Audioengine A2+ and am thinking of upgrading the source accordingly. I do have the following conditions -
*I'm looking for the source to not be powered via an external power source.
*I’m not fussed about any sound manipulation / effects via software. I’m wanting the sound quality straight from the DAC / amp without further tweaking.
*This will be purely for gaming, I’m not using it for any other audiophile use.
*I do have Sennheiser gaming headset which will prob be upgraded last (I understand DT990’s or AKG 701/2 are the ones to consider). Being able to have the A2+ and a headset plugged in at the same time would be desirable.
Based on what I’ve read I think I’m either looking at a Schiit Fulla 2 or a dedicated sound card. If the best solution is a sound card then I will need advice on which one. Over to you
