- 7 Apr 2017
Hi all, I'm having a bit of a headache with how to maximise airflow in my case to get the best configuration since adding a GPU AIO water kit.
I have a Fractal Design Define C case and I have a load of case fans for this now, some of which may now be redundant... I'm running a Noctua d14 CPU cooler with the exhaust fan direct behind it, so the d14 fans are blowing air through in a straight line to vent through the rad and out the back. I can also only mount my GPU rad at the front of the case, as it will not fit at the top of the case due to the d14. I've started redoing the whole airflow, so at present I've got the rad mounted at the front of the case with the two fans attached to the rad blowing air through the rad and out of the front.
My dilemma now is for the rest of the system. I have a total of 5 120mm case fans, so I cant fit all of them so just trying to decide what best to do. I have the vent at the top of the case off now, so I could fit two fans here, either drawing air in or out, but not sure how best to tackle this. I have currently mounted one fan which will draw air into the case from the top and blow directly onto the VRMs and into the d14, not sure if this is a good idea with it pulling air in and then blowing it through and across itself to vent out? If that is fine, then would 2 fans be better than one, or should I have both of these fans drawing air out?
The other option I have is a bottom case fan, I could in theory pull air in from underneath the case as heat rises, then it would eventually get to the d14 and be vented out of the back?
The next dilemma is, I only have 4 inputs for 3 pin PWM fan connections on my motherboard. Is it safe to have 8-10 fans on splitters running over 4 motherboard connections?
I know it would probably help if I had pictures, so I'll try and get some later if it would help!
