getting interference on radio after wiring a Dashcam
2 Jan 2005
West Midlands
hello,
i've added a Dashcam, it get power from a hardwire kit. everything is working but time to time i get random interference when i listen to Radio. i've tried added these EMI filter thing on the Ground wire and positive wire but its still same. Any can help me?
this is the kit ive used:
thanks
A lot of these cheap devices are not actually CE approved, the image itself with the Union flag would ring alarm bells! Where did you get it from?
It’ll be the hard wire kit that’s causing it. I’ve seen several cheap low quality 12v socket adaptors (USB chargers etc) cause this. Buy a better one or buy a decent quality charger and hard wire that with some sort of 12v socket extender.
As above, I binned off the hard wire kit and wired a 12v socket into the glovebox instead. That way you use the adapter that came with the camera and avoid electrical issues like this. That would be the ideal solution.
