This is the go too one at the moment. https://www.overclockers.co.uk/ther...ance-thermal-paste-5.5g-1.5-ml-th-001-tg.html
Kryonaut is probably the best
I wonder if there was something wrong with mine then because mine was like window putty, and just kept rolling when I tried to spread itI just used the applicator that came with Kyronaut. Thin layer over the CPU and done. Had no issues.
I'm using Kyronaut wasn't sure if i was meant to spread it or go with my usual grain of rice in the middle of the cpu? Was a real pig to spread and is probably why i have uneven temps across all the cores on my 1700x so will clean and re apply the next time i drain my loop and go with my usual grain of rice in the middle technique. I've previously used the EK stuff that came with my water blocks without any issues.
Exactly the same here, real pig to spread, going to have to reapply after trying the heating method mentioned above, hopefully that'll work?I wonder if there was something wrong with mine then because mine was like window putty, and just kept rolling when I tried to spread it
Oh dear. This is nonesense. Heat the ihs with hairdryer spread done......I got some thermal grizzly aquanaut and found it an absolute PITA to try and spread and gave up and went back to AS5 in the end
Honestly it’s was like the putty you used to put into windows and no matter what I tried it wouldn’t spread, I got some liquid metal in the endOh dear. This is nonesense. Heat the ihs with hairdryer spread done......
