My CPU is overheating, the CPU fan speed went as high as 4300rpm, the PCH fan 4000 or so. Case fan stayed the same. CPU temp went as high as 79c so turned machine off. Sounded like a jet in my living room.
I have a Medion Erazer spec: Intel Core i7 3930K, Windows 7, 16gb ram, Nvidia GeForce GTX 680, Cougar psu 750w (installed a new psu as the one medion installed was only 600w) ssd hd and seagate 2tb hdd. About 5 year old. Water cooled, cleaned all fans but not the water cooler fan, never replaced thermal paste in all that time. NO noise from water cooler so pump may have died.
Virus checked PC with mcafee and malware bytes but no virus.
It just overheated suddenly, BUt the water cooler has been making a ticking noise similar to a HDD.
Pipes from water cooler, one hot, one cool but the fan itself feels hot!!
If I replace the cooler should i go for air or water. Space may be tight in case
Thanks in advance for help. Bit worried about removing the fan as i don't want to damage processor pins
