new fans
2 Aug 2006
Liverpool
hi, can anyone recommend some good fans, I currently have 2 and Thermalright TY-143sq 140mm and 2
Thermalright TY-143 140mm on my Tthermalright Archon IB-E X2, they are good but too noisy when they ramp up, can someone recommend the following fans for me
2x 140mm
1x 120mm
2x 140mm cpu fans
Colour doesn't matter, price doesn't matter too much
Those fans are very good already, won't get much better than that TBH. Some other good fans are noctua, corsair, EK, Bequiet.
they are good but the noise is too loud and starting to annoy my when they speed up, I've been thinking about getting a 360mm aio would it be worth it
All fans are loud when they are above about 1200-1300rpm really, the ones you have are good, but some are marginally better like the ones I listed.
Not had much experience with that cooler, I know some stock fans can rattle a lot and make loud sounds when at high RPM though. Maybe try the stock ones for a month or so and see how you get on with them.
