Don't waste your moneyI've heard good things about that. Might be my next purchase.
I ordered a rear wiper last week which was half the length of that wiper and came in the same size box.Well done Amazon, looks like they used 1 tree for my packaging, the box measures roughly 30 x 20 inches with a depth of about 8 inches, for an item that measures 29inches long and about 2 inches wide, not to mention the box contained a bin bag full of protection paper, what idiots!
Getter- outers - You have a PITA job
Amazing. I almost want to read it now.
My genius knows no limits.
I have the JayBird X3 earphones, they are superb but have only one flaw. The charger dongle uses its own pin type connection, and on the dongle is a MicroUSB port in a world where everything else I own is Type-C. So I've been carrying around the dongle with the Micro USB cable as shown above the dongle below:
Came across Type-C (female) to Micro USB (male) with good reviews, metal in build quality too. Now can keep the dongle attached at all times, and it's not bulky to be a nuisance either on the neck:
I bought the Jaybirds but thought they were horrendous. I've heard significantly better earphones for £10
I consider them to be very very close to the Sennheiser IE80 I had before them. Wireless freedom meant I sold the IE80s.
You absolutely must use the MySound JayBird app to tune the built in DAC to your preferred sound (it stores the changes directly to the earphones), and depending on your phone, tailor your phone's output to the new earphones and your ears on what frequencies they can hear. On Samsung phones you have Adapt Sound which does exactly that.
If you don't do either of these things, then you won't be hearing what they are capable of. You also have to use ear tips that make a full seal inside your ears. For me the large size comply memory foam tips were the only ones that created the best seal.
They definitely are not an earphone that you can unbox and use and expect fantastic sound you really do have to tailor them to your ears and phone.
I tried all the different EQ's in the app, but I thought they sounded terrible. Not even close to my Sound Magic E10's... cant imagine they were a patch on a pair of IE80's?!
I love the idea of wireless headphones, they'd be great when i'm rowing, but from what I'd read these were these were meant to be some of the best sounding wireless out there and they just didn't cut the mustard for me.
Any others i should be checking out?
