Stuck in a food Rut
Thanks guys for the replies.
I know my post was a bit random and not clear but The reason I asked for suggestions and recommendations was i wanted to get ideas on other things to try, originally i never wanted to try currys or past but eat them every week or so now, so i thought other could give me some suggestions to try.
I may open a new thread on food recommendations.
The best way to try food is travelling, you are forced to eat local foods as they tend to be the cheapest, unless you are one of those who like to go to McDonald’s abroad.
I came back from Japan with a ton of inspirations for food and have been eating it now 3 days a week since I got back.
Like Shoeyuk a few post above, carbonara is very quick and very easy. Not tried it with cream, I loosen it a little with the pasta water. Might try cream next time :)
I do however like to use a packet of that cheap as chips smoked salmon offcuts chopped up and mixed in before serving.
Do you have a recipe for this? :D
You can do it properly with chicken breast, panko or….
get pre made chicken in breadcrumps, Sainsbury's makes the best one (I've tried Waitrose, Co-op and Morrisons to compare).
Then get a pack of this.
https://yutaka.london/products/japanese-style-curry-100g-serves-5
You only need to dilute it with water in a pan.
SUPER easy and I must say…..it's not far off what I had in Japan and that is saying something.
Fed up with frozen foods (pizza, fries, fish fingers) and basic stuff i know jacket potato's chips, curry's Indian rice, takeout just to give you a basic ideas I dont know how to make a lot of stuff outside this basic area.
So, bluntly, you know nothing. Don't worry; many of us were there once. And you're cooking for just yourself, which, ironically, makes things more difficult.
I have two recommendations: get Delia Smith's book One Is Fun, and sign yourself up for a basic cookery course.
Oh, and don't follow the directions for carbonara above. You just want the egg yolk, not the white, and a little cream or creme fraiche.
Quartz's quick carbonara:
You need 100g spaghetti or other pasta. 2-3 rashers of bacon. 1 hard cheese like Parmesan. 1 or 2 eggs. Cream or creme fraiche. 1 large saucepan. 1 frying pan. 1 mixing bowl. 2 litres of water. 2 rings on a cooker. 1 wooden spoon. 1 spoon. 1 chopping board. 1 large sharp cooking knife or cleaver. 1 mandolin / grater. 1 sieve. Pepper and other spices to taste.
Time: 20 mins.
Turn the cooker on and turn the rings to max.
Put the water in the saucepan. You want the saucepan to be less than ~2/3 full. Put the saucepan on one of the hot rings.
Cut the rind off the bacon, and chop the bacon into strips with the cooking knife or cleaver. Put the cut bacon into the frying pan. Do NOT put the pan on the heat.
Use the medium grater side of the mandolin to grate some cheese into the mixing bowl. This is to taste, but you don't need much - 2 inches off a triangle of Parmesan. Add the egg yolk(s), and a small spoonful of creme fraiche, mix thoroughly and set aside. If you get a paste when you mix it, add some more creme fraiche (gently does it).
By now the water should be boiling. Put the pasta in and reduce the setting so that the water roils but does not boil. Check the spaghetti packet for the time but it should take between 10 and 15 minutes to cook. Tamp down the spaghetti with the wooden spoon so it gets fully submerged. DO NOT add olive oil. (You want the carbonara mix to stick to the pasta later.)
While the pasta is cooking, put the frying pan on the other ring and fry the bacon. Move the bacon about with the wooden spoon so it doesn't burn.
If the bacon finishes cooking before the spaghetti, set it aside, still in the pan.
Once the spaghetti has finished cooking, fish out a strand with a fork and taste it. If it's not cooked, give it another few minutes and repeat.
Once the spaghetti is ready, pour it through the sieve and give the sieve a shake. Turn off the cooker.
Now combine the cheese mix, the spaghetti, and the bacon in the mixing bowl. Stir thoroughly, but not so much that the egg scrambles. The heat from the spaghetti will cook the egg and melt the cheese.
Turn out onto a warm plate or bowl.
Grind some pepper onto it.
Eat!
You can experiment by adding mushrooms, spices, etc later.
Oh, I thought you had made the sauce from scrach. Good to know the packet stuff is decent though. I'll consider it next time I'm in the shop.
I can make it from scratch but the packet stuff is sooooooo close, it’s better than Wagamama and close to the real deal, I don’t think it’s worth it to make it from scratch.
