Painting TV bezel
7 Aug 2017
Oxford
Just bought a Samsung TV at a local clearance sale and although the TV is perfect the silver bezel does not match the other furniture. Has anybody painted their TV bezel? Wouldn't mind a non permanent solution which can be removed easily in the future.
29 Nov 2002
Midlands. UK
Are you planning to remove it entirely then paint, which is what I would suggest, As I personally wouldn’t just do it by masking..
Get a good plastic undercoat first as paint on plastic always rubs off sharp edges if not. And maybe a nice top coat to protect it. Plastikote is a good brand, apply thin and build it up.
OP
7 Aug 2017
Oxford
I would rather mask/cover it with the pvc trim as it's much easier to remove if needed. I would certainly not remove the bezel to paint it.
