17 Feb 2018 at 11:35 #1 Faded Faded Soldato Joined 12 Sep 2006 Posts 3,115 Location Essex Is there a way to put a pin/password on a folder which contains multiple apps on iOS? Even through a third party app? Thanks
17 Feb 2018 at 17:36 #2 Feek Feek Commissario Joined 16 Oct 2002 Posts 344,216 Location In the radio shack You might find a way to do this if the phone is jailbroken but not otherwise.
17 Feb 2018 at 19:03 #3 Faded Faded Soldato OP Joined 12 Sep 2006 Posts 3,115 Location Essex Feek said: You might find a way to do this if the phone is jailbroken but not otherwise. Click to expand... Ah okay, it's for the kids iPad. I wan't to prevent them from going in to certain apps like Safari. Don't really wan't to be jailbreaking the device.
17 Feb 2018 at 19:11 #4 Feek Feek Commissario Joined 16 Oct 2002 Posts 344,216 Location In the radio shack Easy - Parental controls to block apps. See here.
18 Feb 2018 at 14:03 #5 Faded Faded Soldato OP Joined 12 Sep 2006 Posts 3,115 Location Essex Is that for Apples apps only? I also have a few of mine on there like the Giant Bomb video app which I would prefer them not to be able to get into.
19 Feb 2018 at 13:16 #6 Deleted member 138126 Deleted member 138126 Only for Apple stuff. Works well though (although it's tedious to enable/disable).
