I'm finding myself torn with what to do with a side door which leads into my lounge. It gets in the way of where I want the TV to go, so I need to move it at the very least, but I don't want to lose the light it lets in.
Looking in from the side garden, it looks like this:
The lounge floor-plan looks like this:
(With the back of the sofa against the wall that contains the two cupboards, the current position of the doors means the TV/etc won't fit on the opposite wall)
I'd never use the doors as doors, so the easiest option is to install a large window to the side of where they are now. But that seems a little dull, plus it leaves me with having to install shutters/blinds over it for privacy reasons. Not that you can see in from the side garden, but without them it would look a bit weird.
Would a similarly-sized opening of frosted glass blocks work, or would they look totally out of place on your run of the mill semi-detached?
