If time is infinite then there must have been something before the big bang.
Nope , why would it?Also, if time is infinite then every possible scenaro will be played out.
Matrix worldAlso a option that we are living in a simulator so no Big bang or God.
.I take comfort in the fact that some genious who is yet to be born will figure the whole thing out.
Matrix world.
You clearly don't understand infinity. Your statement is self-contradictory
Time is not infinite.
only because it's garbage. point me at the science book/site that support "every possibility weill be played out so i'll return as a spider or the POTUS" and i'll reconsider.I know the difference with science versus religion. You, seem to have a problem understanding my post.
It doesn't have a beginning or an end because time is not actually anything apart from something we have thought of. I was under the impression we as Humans invented time.
If that makes any sense whatsoever lol
time is a real thing, we just invented terminology to describe the dimension that is used to determine the change of state of the universe.
I don't have a problem with the definition of infinity. Why would you say that?
Or is time a illusion?
i wouldn't say so, it's effects are measurable. unless of course everything else is an illusion, but then i don't have enough tin foil to subscribe to that.
I'll write up my theory later on when I am at a proper keyboard. But for now consider this...
Time exists as part of Spacetime. Before the big bang (assuming that theory is correct) time didn't exist. If the universe ends, either through a crunch or a freeze then tine will also probably end.
Without time there is no past and no future. So in the past we didn't exist in that future (because time didn't exist) and in the future we wouldn't have existed in the past (because time ceases to exist).
So we really don't exist right now.
