Usb 2.0 header to usb 3.1 gen.1 port
Are you sure that this is compatible with the motherboard?
I was thinking about that:
USB 3.0 20-Pin Motherboard Header Female to USB 2.0 9-Pin Male Adapter Cable
If it has that USB2 end without pins showing in it then it's the right kind adapter.
Assuming they got pin thickness right in USB3 header, because USB3 has thinner pins.
(got one such adapter with erroneous pin thickness)
Adapter meant for connecting USB2 of case to motherboard's USB3 header would have pins sticking out from its USB2 end.
thank you my friend.
