If you want something cheap to try and can sell on if you don't get on with it Note4.I'm currently using an iphone 6plus so grabbing a xiaomi will be fun and new to me but I'm used to android anyway.
How hard are they to root? As hard as updating/changing bios on mobo or gpu?
Cheers
I'd avoid buying Chinese phone if you aren't confident you're able to load a stock android on it. The hardware is good, but the bloatware on all of these phones, including xiaomi is pretty terrible if you're used to being in control of what is on your phone. Samsung is the worst, but the others are similar.
Not available yet but seems to have a £150 ish price tag can only wait till it appears online.
For £150 well worth the wait.
Will you be buying one mate?
Cheers![]()
No mate i have a Oneplus 5T sold my Xiaomi Mi5s to get it.
Wouldn't the Nokia 7 be priced around that bracket? Just wait a few days to see the pricing.
Ok mate nice one
Is aliexpress best place to get Xiaomi?
Ali,gearbest,banggood all the same really.Remember the warranty is next to useless from them as it will cost an arm and leg to send back and forth to China.
Can anyone with a Xiaomi Redmi 5A confirm that it takes a nano sim card? I've seen references to both nano and micro and I'm about to order a new sim for the wife (we pay €10 each for them here...)
Definitely Nano sim, i think your seeing Micros SD memory card slot in the specs.
I think most sims you get these days cover all sizes anyway,you just pop out the one you need.
Thanks for the heads up @Kelt hope you left a review for others to see
