I'm trying to find out what type of roof terminal I need for a kitchen extractor.
Some background info: We've had an extension built, but the kitchen has not been moved. Also there is a utility room next to the kitchen, and therefore the shortest route for the extractor ducting is horizontally to the utility room and then out through it's pitched roof (roughly 23 deg).
So, my question is - should I need to use a insulated roof terminal like this http://www.ubbink.co.uk/products/Roofing/Roof-vents-terminals/Universal/UB46-47-48.aspx to reduce condensation? Or would a regular terminal (steel/plastic) be fine for this purpose?
Thanks
Thanks
