I've moved into a new build and have a "Megaflo Unvented Direct Eco" cylinder boiler. Water pressure is intense. Guessing direct means straight from mains? Showers are crazy good.
Since moving in I have had both mains switches turned on behind it. They appear to have wires leading to 2 titanium immersions attached on side of the boiler.
My question is do I need both on? Or just one? It's just me in the property. If I do switch one off (guessing 2 might only be needed for loads of hot water demand) which one should I switch off? The top or bottom one?
It cut-off on me recently and I had to get an electrician to come and reset the thermal reset cut off. Once done it filled up and heated water ok. Hoping it doesn't occur again. Anyone know what might be the cause?
There are no timers for it. Just 2 mains switches. So when both on I am guessing it heats up the max amount of water. Perhaps that was the issue.
