- 16 May 2005
- Manchester
any pics, or google pics?
The OP has a link to some pics.
Mine turned up today! No idea what to cook first!
The Serious Eats chili verde is a good first recipe. Really delicious and minimal hassle.
thanks, that looks insane.The OP has a link to some pics.
Tomatillos, best place to buy from that I can actually get to?![]()
Space is limited in my kitchen, and a lot of the recipes I have and have been given from my community (Anglo Indian) use normal stove top cookers, so it's really sticking with what I know. What are the benefits of an electric one?why specifically a stove top PC not an electric one?
Don't bother with them. Just substitute with a small amount on unripe cheapo tomatoes. Not quite the same but you'll struggle to notice the difference![]()
Thanks, did see this elsewhere and chuck in a little lime juice.
Something like this?Massive amount of safety features. No need to tweak the heat to keep under pressure. Once food is prepped and it's on you can walk away from it. You can also cook on another work surface whilst using the hob for other things. They are slightly larger than a stove top one though.
Tomatillos and tomatoes really aren't like each other. They are easy to find canned on Amazon and specialised good sites. Give them a go.
Just the standard serious eats, rub in seasoning browned the skin in the cooker for about 8 mins turning every few. Then chuck in stock place chicken on steamer bit close and leave for 30minutes allow yo naturally release pressure for 10 mins then open rest and serve.
Ft, I did the mushrooms risotto last night. Incredible.
So about an hour in total? Not too different from roasting a chicken normally, surely.
Personally I roast for longer at a lower temp and then just crisp up at the end. It's at least a 2 hour process if I'm doing a full chicken this way. Obviously spatchcock and ballotine change things somewhat.
