Recommend Free Realtime Network Usage Prog?
15 Oct 2007
Bedfordshire, UK.
Can anyone recommend a program that shows realtime (in bar graph form) network usage for both wireless and wire usage,or does windows 10 even have a built in program?. I was hoping my Linksys router would have such a feature but it doesnt appear to, thanks
That just shows activity on the PC though doesnt it, it wouldnt show wireless activity on the network like consoles and phones?
In that case, Unless all traffic is running through the PC (IE is being used as a router) then this isn't possible. You'd need to find something at router level which, as you say, yours doesn't have it.
Ah ok is there a 3rd party app that can commicate at router level then?
I think the only "decent" answer to this is that you need a router that will give you these stats and there isn't an answer that doesn't involve investment of £'s.
This'll only work if the router supplies the data for an external device to read/use. I imagine only the high end consumer routers would have such features if any since this isn't something the typical home user would even need. Alternatively you can build something like a pfsense box which probably has a module for it but that requires a bit of knowledge and DIY.
You could flash the device with the dd-wrt firmware and it may give snmp access or even give live data from the web interface, its been a few years since I've toyed with it :)
