Helloooo
Thought I may as well ask here...
E30 has a stainless Scorpion centre exhaust on it, its quite old and has been bashed about a few times.
It makes a really annoying/loud echoing sound, a bit like someone blowing over the top of a glass bottle, which is louder at certain RPM's.
If you apply pressure to the bottom of the silencer, it almost completely stops the noise.
I tried lashing it to something so that any vibration is taken out of it/damped, but there isn't anywhere really to lash it to, and its a bit of a hillbilly fix.
Any ideas before I either - Start hitting it with a mallet, or, cut it open, try to figure out whats going on and weld it back up, or, stick it on eBay.
Danké
Danké
