- 29 Mar 2004
- Cambs, UK
Hi all,
We're having our kitchen and dining room redecorated and as part of that having a new kitchen fitted, ceilings skimmed and spotlights installed.
The installer has asked how many spotlights we need. To be honest I don't have an idea. The 2 rooms are being converted to one (wall in the middle removed and ceiling supported using an RSJ). They're evenly sized rooms of about 3m x 3.5m each.
Has anyone else had to work out how many spotlights to install, and if so, how did you, and did you get it right?
Many thanks for any help.
Edward
Edward
