I acknowledged that a couple of posts later. I'll edit to show this when on a pc.I agree with your post mostly but you clearly missed the joke in the “Wind her neck in” one. Hint: he kissed her on the neck.
I'm not suggesting it was, I'm just pointing out that you're also using assumptions to come to a conclusion.I'm not trying to fit a narrative, I'm offering my opinion on why a story getting reported as if it was very minor might have resulted in an apparently harsh sentence, especially so given the difference in wording when you read the same story on local news outlets.
Putting your arm around someone from behind and managing to keep them there long enough to kiss their shoulder, neck and head isn't just a friendly arm around the shoulders as was being implied.
I'm using assumptions to reach an opinion on what I think might have happened, I'm not 'concluding' anything. I'm perfectly entitled to be forming an opinion and my personal opinion doesn't need to be held to an equivalent journalistic standard as a national newspaper.I'm not suggesting it was, I'm just pointing out that you're also using assumptions to come to a conclusion.
That was just an example of someone I know that does this. I know more people that do it, people who aren't my mum.A mum doing it to a son is completely different.
You are coming to a conclusion that the situation happened differently than what the paper is reporting, you're expressing an opinion on the article. You might not like that particular phrasing, but that's how that word works.I'm using assumptions to reach an opinion on what I think might have happened, I'm not 'concluding' anything. I'm perfectly entitled to be forming an opinion and my personal opinion doesn't need to be held to an equivalent journalistic standard as a national newspaper.
I used the wording 'I'd be wholly unsurprised', specifically because I'm not concluding anything did or didn't happen, just that it would not surprise me to learn there was more to the incident than what was initially reported. What follows is my speculation on what that might be.You are coming to a conclusion that the situation happened differently than what the paper is reporting, you're expressing an opinion on the article. You might not like that particular phrasing, but that's how that word works.
Opinion and conclusion are synonyms... So yes, that's exactly what you're doing.
You're perfectly entitled to an informed opinion, but it doesn't really seem like you're trying to actually inform yourself by looking for different sources of the same story.
Because of all the accusations that later turn out to be false, after of course the guy's reputation has been trashed.Well why do you assume all women are lying for instance?
Conclusion and opinion are synonymous. Words have meaning, and that meaning is rather important.I used the wording 'I'd be wholly unsurprised', specifically because I'm not concluding anything did or didn't happen, just that it would not surprise me to learn there was more to the incident than what was initially reported.
If saying I wouldn't be surprised by something is equivalent to coming to a conclusion that it happened in your book, then yeah that's what I did if it makes you happy.
Yes, the phrase 'I wouldn't be surprised' also has meaning and I used it for a reason, because I wasn't drawing a definite conclusion. Otherwise I'd have just stated what I thought in more definite terms.Conclusion and opinion are synonymous. Words have meaning, and that meaning is rather important.
What’s clear is that the spectre of false allegation continues to dog the reporting of sexual violence. There remains a public impression that false allegations are common and that innocent people suffer as the result of being wrongfully accused.
The evidence on false allegations fails to support public anxiety that untrue reporting is common. While the statistics on false allegations vary – and refer most often to rape and sexual assault – they are invariably and consistently low. Research for the Home Office suggests that only 4% of cases of sexual violence reported to the UK police are found or suspected to be false. Studies carried out in Europe and in the US indicate rates of between 2% and 6%.
But I never said definite conclusion. Conclusion and opinion has the exact same meaning in this context. I'm highlighting that you did exactly what you said the news site was doing.Yes, the phrase 'I wouldn't be surprised' also has meaning and I used it for a reason, because I wasn't drawing a definite conclusion. Otherwise I'd have just stated what I thought in more definite terms.
exactly - but none of the posters replying and making little of the incident would admit they wouldn't be ok with that. I imagine most would claim to either (a) laugh it off and so would their partner or (b) go all alpha on the other male....when in reality they would most likely do neither.I think that is a good barometer tbh.. would you be happy if someone did it to your wife/girlfriend in front of you... if not then it probably isn't OK. I'm guessing most people would be ok with a hug/kiss on the cheek... but multiple kisses including the neck etc.. very dubious and if unwanted then yeah it could easily be sexual assault.
Well I can only apologise profusely for any upset that I've caused by not holding myself to the standards of the national press.But I never said definite conclusion. Conclusion and opinion has the exact same meaning in this context. I'm highlighting that you did exactly what you said the news site was doing.
I'm guessing there's a lot of 'lads' bravado at play in this thread. at least I hope there is, I really do not like the idea of so many (relatively) members of this forum holding such utterly obnoxious views.
I'm not upset, you're just denying the definition of words.Well I can only apologise profusely for any upset that I've caused by not holding myself to the standards of the national press.
No I'm notI'm not upset, you're just denying the definition of words.
You said an opinion isn't a conclusion, that's literally denying the definition of words.No I'm not
No it isn'tYou said an opinion isn't a conclusion, that's literally denying the definition of words.
