due an upgrade android only £550
emu
emu
30 Jun 2005
hi with so many phones on the market im due to spend 550 next month on an android handset.Phones i have looked at so far
htc u11 ultra
mate 10 pro
anything else i should be looking at? camera,battery life and audio output are important
thanks
26 Mar 2007
Nottinghamshire
I've just sold my Mate 10 Pro.
Absolutely everything about it is superb except for one crippling aspect for me that nobody talks about which was that the controls (Play / Pause / Skip Track) on any Bluetooth device don't work, tried it in both my cars, on 4 different headsets, soundbar and TV. Other than that I would heartily recommend it, the build quality, battery life, camera, speed and responsive is absolutely brilliant.
6 Dec 2012
notts
it works just fine on my mate 10 pro, i use it with bluetooth headphones and it will play/pause skip fwd and back all from the headphone controls.
i may try it in the car later and report back.
17 Aug 2003
Woburn Sand Dunes
Yeah me too which was why it was a show stopper for me. Can't believe that none of the reviews etc even mention it.
I actually sent my 1st handset back as faulty and got a new one in return but it was exactly the same.
Do you not think that given you've had somewhat unique bluetooth issues with both the S8 and mate the Mate 10 pro that maybe it isn't or isn't just the phones that are the problem?
emu
emu
OP
30 Jun 2005
would the lg g6 still be a good choice? i can pick one up very cheap
now im also adding the lgv20 and lg v30 to the list . looking at the lgv30 because of the audio performance
26 Mar 2007
Nottinghamshire
Got a Note 8 now and everything is fine, the S8 is actually my works handset and they replaced it and everything is fine on that too now.
All of my hardware works perfectly as it should, had no issues with the Mate other than the controls.
30 Dec 2017
V30 all the way, just make sure you check the screen immediately, there are a lot of panels out there much worse than what can be seen on the Pixel 2 XL.
Permabanned
17 Aug 2016
htc u11 ultra
mate 10 pro
thanks
You may not know it but there are now deals to be had on the Pixel 2 XL, Google's flagship phone, which originally launched 5 or 6 months ago at £ 799 for 64 gb and which is now in your price range. I am delighted with my Pixel 2 XL, the top of the line camera, the excellent battery and audio output (although I usually listen via Google Pixel Buds), the immediate system and security updates, the original Google Lens feature, etc.
This recent article from Android Authority has the phone on a 12 month SIM only deal at £ 529. Check it out.
https://www.androidauthority.com/deal-google-pixel-2-xl-carphone-warehouse-845931/
10 Apr 2009
Super Leeds
I've just got a Mate 10 Pro. The phone itself is excellent. Looks very nice, has incredible battery life. The camera is supposed to be excellent but I haven't had much chance to use it due to this crap weather. My only real issue is the software. I much prefer stock Android.
