980Ti fan failing help!!
27 Jul 2005
The Orion Spur
Grrrrrrrr, this is a real bugbear of mine, so many expensive components out there held captive by a 50p fan on an otherwise fully working product!
I have a Palit Geforce 980 Ti Super Jetstream GPU and one of the fans is starting to fail, it's 5 months out of warranty and not sure what to do, there is noway I want to give it up for the sake of a fan, I've emailed jetstream support but haven't heard back from them yet :-(
Any idea's what I can do?
This is my GPU - https://www.techpowerup.com/reviews/Palit/GeForce_GTX_980_Ti_Super_JetStream/4.html
I've looked for spares on ebay but no joy, a few gigabyte ones seem do crop up, not sure if I can bodge them on my card or not, have even considered water cooing but quite expensive and a lot of effort, don't really want to go down that road.
If you look at the heatsink in the link maybe I whack two 120mm fans on there some how?
You can ghetto that quite easily as you suggested already with a couple of cable ties and some 120mm fans, would seem the easiest route.
Totally just do a ghetto job. Remove and disconnect the original fans, whack 2 slim 120mm fans on there instead.
If only one of the fans is failing I think the card is good enough to truck on with just a single fan, as long as your case isn't a hot-box.
In what way is the fan starting to fail. Are you sure it isn't something a bit of lubricant can't fix? Worth a try before you do anything drastic.
There's Jetstream fans available in 90mm, 95mm and 100mm on Chinese import sites. Pretty steep though ($31.99 to $41.99). Otherwise you could do what linus tech tips did in a recent video and remove the metal shroud along with the fans and just cable tie two low amp fans to it.
https://youtu.be/-yQHAMz1v5g
Thank you, just managed to find them, isn't bad a price actually for a pair of them plus free delv.
Remove the whole plastic shroud and cable tie a couple of 120mm fans to it. It'll be much quieter and a bit cooler even, just not as aesthetic. You can even buy a 2 way 3 pin splitter and attach it to a VGA fan adaptor (Think Gelid do one) so you can control fan speed through software.
If it did go that route or at least try it out first as I have a few fans kicking around what would I connect the fans to, a fan controller?
You can get a adaptor for fitting normal fans to a gpu so that they are still controlled by the gpu itself. Last time I checked there were several on Ebay that were less than a fiver.
