10G network with 3 hosts
23 May 2007
Hi all,
I'm looking at setting up the following:
2 x ESXi 6.5 hosts. Each host has a 2x10Gb NIC.
1 x desktop PC. This has a 10G NIC (single).
1 x Netgear Nightawk router with 1x10G NIC
I have a fibre going from my current server to the Netgear router and this works fine.
I would like to know if the below is the right way of doing it:
mpgjd3zcydw6liz-jpg.58649
The desktop PC won't be on all the while so I may need a switch between that and the servers..
Any thoughts?
You want a switch really, otherwise you're software bridging which is not nice.
I don't really think you need 10Gb though.
I'd certainly look at a switch. Like @Caged says, software bridging isn't nice and you could stand to lose a fair amount of throughput using it.
I disagree though, 10G is exactly where you want to go!
Thanks both, I must admit I’ve never heard the term ‘software bridging’ before?!
I do have a spare switch with 2x10Gb SFP+ ports but not sure that would be sufficient?
10Gb maybe overkill but I’ve got the fibres already in and have everything else apart from maybe a switch so why not!
It's because the switches are still a lot of cash per-port.
A two port switch isn't going to help you replace a cable unfortunately.
You definitely need a switch, plus if you’re planning on more advanced features by using vCenter then you’ll need at least two VLANs. A 10Gb switch will not be cheap though. Unless you have a need for 10Gb (such as all flash VSAN, though for home use 1Gb works), I’d just get a 1Gb managed switch. I have a 10 port Cisco small business one for sale on here. T
Chris,
Do you have a link to the switch - couldn't find it with a quick search..?
It's copper though, was under the impression the OP already has SFP+ modules and NICs
Quite correct, I have the 10G cards and fibre already installed. Nothing stopping me acquiring some 1G SFP's though I guess.
I have found an Ubiquiti SFP+ switch (16XG) so will be having a look at that..
Hmm, shall have to make a decision on whether to go and spend more money on the 10G 16-XG or run with an SG300-10SFP for now. There's a fair cost difference as to be expected. In reality the 1G solution would be fine.
What are you planning on doing with VMware? If it's a home lab, I'd just get 1Gb.
Chris,
It hosts my email, will be doing some web site hosting and various other tasks (private cloud etc). It will also be running a Plex server with all content hosted locally. May have upto 5 concurrent users, possibly with demand for 3 to 4 HD streamed movies at any one time.
The more I look at the SG300-10SFP the more I am tempted.. quiet, low power, not overly priced.
Sorry, missed the fibre bit.
16XG is unbeatable in price!
https://www.ubnt.com/unifi-switching/unifi-switch-16-xg/
https://www.ubnt.com/edgemax/edgeswitch-16-xg/
Two options, Unifi = you'll need a controller on another PC/Device to manage the switch, Edgemax = controlled on the device (or by optional controller)
Whichever one you get, there'll be firmware upgrades out of the box for it :)
If anyone is looking for a US-16-XG, make 100% sure it’s the Rev. 11 or Rev. 12 model as the ones before that had hardware issues and UBNT are currently RMAing them all.
