GPU upgrade from 7970 for 1440
7 Aug 2009
midlands
Hi all,
After many years of faithful service it looks like my trusty 7970 is about to fail and I would like to know what GPU I should look to replace it with.
I game at 1440 and either make will be fine.
I'm looking for a card with a bit of room as I don't game heavy anymore but you never know when something will grab you, no freesync or gsync plans so max 60fps required.
Any guidance would as always be appreciated.
10 Sep 2009
Budget? Used or new? There’s not much choice. You might get away with an RX580 or GTX 1060 but really a 1070 is required for comfortably running 1440p60.
OP
7 Aug 2009
midlands
Hi MSTRBKR,
New is what I would like, budget is a flexible £500 but prices are crazy.
I was looking at the 1060's but unsure and now I shall have a look at the 1070's.
Do the RX580 and the 1070 range perform around the same?
3 Jan 2006
Chadderton, Oldham
I had the 7970, I felt the only worthy upgrade was a GTX1080, whole world of difference and isn't like a vacuum cleaner. Price tag is hefty as you know. If you've got 500 quid I wouldn't settle for less than a GTX1080 tbh.
OP
7 Aug 2009
midlands
Might have to get a bit more cash together for the 1080, nice to know it feels like an upgrade.
I dont see the Palit dual OC on the 1080 list, will google that later.
3 Jan 2006
Chadderton, Oldham
It's scary to see that some minimum system req's for games have a GPU that is faster than a 7970! And at 1440P and 4K it's defenitly better, at 1440P my 7970 could just about managed GTA V on mostly max settings but shadows, grass, no AA, the GTX1080 I can crank it up all the way now, and that's at 4K too. It's a good 4 times faster I rekon at least.
25 Jan 2007
As others said, 1070 as a min, maybe a used 980 TI if you want to 'save' some cash, but the last time i saw those prices, seem pretty high too, if i sold mine for around that, i'd feel guilty.
Back in 2H 2015, i went from 7970 to 980 TI, a good upgrade, but with 6GB, starting to show its age @ 2560 * 1600
1 Nov 2013
Ireland
Minimum requirements these days are a pile of hot garbage that actually have no relation to reality. I sometimes wonder if they're just made up or if they actually get some sort of kickback form GPU manufacturers for grossly inflating requirements.
You're right - there are games that list cards like HD7950 as a minimum - then the game ends up running at 1080p high settings on that card.
Dunno, maybe developers are now just seeing 'minimum' as in 'the minimum we recommend to enjoy the game the way it should be run', eg 1080p mid-high 60fps.
Minimum requirement used to mean, literally, the minimum requirement to run the game at low res/low-medium settings relatively well. Now it seems to mean 1080p high in most cases.
Permabanned
12 Sep 2013
Knowhere
Hi MSTRBKR,
If the 7970 hasn't broken down yet try and wait, Todays pricing is terrible and options are poor, Plus on the green side the current architecture is close to 2 years old so something new can't be that far off so waiting will be a good move as old stock may drop in price along with lots of Pascal cards appearing on the secondhand market, Also, you could ask Gibbo if any deals are coming up as he does offer deals not on the main shop front, Do you have access to the Members Market? A few decent GPU's have been selling on there recently so if you can't wait or the 7970 does die visit the MM on a regular basis.
Caporegime
8 Nov 2008
+1
OP
7 Aug 2009
midlands
No death on my card as yet. I can hear coil whine now when I game and I tried the beta of Sea of Theives and it defaulted to 1080 resolution at high.
No plans to pull the trigger right now but its been a while since I was looking for a GPU and thought i would ask the wise forum members for advise.
I can go to members market but prefer to get a nice new shiney card.
Just praying prices drop a little by the time I need to purchase.
14 Apr 2014
Sunny Sussex
Yeah, if you want to run ultra.
Be clever with your settings, and a 1060 is more than good enough. High textures with good effects and lighting and you probably wouldn't be able to tell the different Vs ultra, unless you're looking for the detail, and then you're not really playing the game.
OP
7 Aug 2009
midlands
As always with opinions they are bound to differ.
I can see from the comments that a 1060 will suit my gaming but a 1080 will give room to spare.
I'm gunna keep my money and pray for a drop in prices and hopefully pick up a 1080.
Now the question is which one.?
