It's not something that can be delivered in a driver. Just like you couldn't make dx11 cards run dx12.So NVIDIA cards only gets 1 years worth of driver support then nerf?
Sure I can give examples of game engines.Do you have examples of where this was used in game engines?
I've just ran a full ray-trace on a simple lamp with a green glass shade and reflective brass, and it took 40secs with no background other than white.
It can be done via a driver and old GPU's can support it if NVidia choose to go down that path.It's not something that can be delivered in a driver. Just like you couldn't make dx11 cards run dx12.
Possibly but Power VR were using their own gpu, vulkan, and android, which means they're getting these gains by circumventing communication with the os layer.It can be done via a driver and old GPU's can support it if NVidia choose to go down that path.
That doesn't have to be the case PowerVR did the latter and it still worked on older cards and even none PowerVR GPU's. I see no reason why NVidia cannot choose to do the same thing. If anything the word optimized for Volta suggests it will work on everything only that it will work on Volta better.Possibly but Power VR were using their own gpu, vulkan, and android, which means they're getting these gains by circumventing communication with the os layer.
I've ran suntemple and it wasn't great. Think I did it on a 980 tho, could try on 1080ti.
This partnership with MS for a dx api is unknown, it could either be an extension of dx or a means to fully bypass windows with minimal overhead. If it's the latter it won't work on older cards.
They have said it's optimised on Volta for RTX, so by extension the gameworks version should work on older cards. Either way it's not going to be a nice experience by the sounds of it.
For today’s reveal, NVIDIA is simultaneously announcing that they will support hardware acceleration of DXR through their new RTX Technology. RTX in turn combines previously-unannounced Volta architecture ray tracing features with optimized software routines to provide a complete DXR backend, while pre-Volta cards will use the DXR shader-based fallback option. Meanwhile AMD has also announced that they’re collaborating with Microsoft and that they’ll be releasing a driver in the near future that supports DXR acceleration. The tone of AMD’s announcement makes me think that they will have very limited hardware acceleration relative to NVIDIA, but we’ll have to wait and see just what AMD unveils once their drivers are available.
Though ultimately, the idea of hardware acceleration may be a (relatively) short-lived one. Since the introduction of DirectX 12, Microsoft’s long-term vision – and indeed the GPU industry’s overall vision – has been for GPUs to become increasingly general-purpose, with successive generations of GPUs moving farther and farther in this direction. As a result there is talk of GPUs doing away with fixed-function units entirely, and while this kind of thinking has admittedly burnt vendors before (Intel Larrabee), it’s not unfounded. Greater programmability will make it even easier to mix rasterization and ray tracing, and farther in the future still it could lay the groundwork for pure ray tracing in games.
Unsurprisingly then, the actual DXR commands for DX12 are very much designed for a highly programmable GPU. While I won’t get into programming minutiae better served by Microsoft’s dev blog, Microsoft’s eye is solidly on the future. DXR will not introduce any new execution engines in the DX12 model – so the primary two engines remain the graphics (3D) and compute engines – and indeed Microsoft is treating DXR as a compute task, meaning it can be run on top of either engine. Meanwhile DXR will introduce multiple new shader types to handle ray processing, including ray-generation, closest-hit, any-hit, and miss shaders. Finally, the 3D world itself will be described using what Microsoft is terming the acceleration structure, which is a full 3D environment that has been optimized for GPU traversal.
Though even with the roughly one year head start that Microsoft’s closest developers have received, my impression from all of this that DXR is still a very long-term project. Perhaps even more so than DirectX 12. While DX12 was a new API for existing hardware functions, DXR is closer to a traditional DirectX release in that it’s a new API (or rather new DX12 commands) that go best with new hardware. And as there’s essentially 0 consumer hardware on the market right now that offers hardware DXR acceleration, that means DXR really is starting from the beginning.
AMD collaboration
HEXUS received an email bulletin from AMD about its own work on Microsoft's DirectX Raytracing API. It said that it was "closely collaborating with Microsoft," on the future of the API. More specifically it is helping to "define, refine and support the future of DirectX12 and ray tracing". Without mentioning any of its own hardware/software technologies, AMD said that it "remains at the forefront of new programming model and application programming interface (API) innovation based on a forward-looking, system-level foundation for graphics programming." AMD hinted that it would have more to share about PC-based ray tracing techniques in the future.
Metro Exodus apparently.
Very impressive.
Break out the chrome spheres and checkerboards![]()
The difference between the two images is matte vs glossy surface with reflections, and more transparency/different colour of the second image.Do you have examples of where this was used in game engines?
Normal modelling view vs. Ray Traced
Showing your age there budYay finally we'll be to render Space Harrier the way it's meant to be played![]()
