I have a Caple cooker hood and the one of the downlights has blown. The manual advises the bult spec to be 20 halogen lamp 220-240V 20W.
I've removed the faulty bulb and it looks like this:
https://www.homebase.co.uk/halogen-g4-capsule-20w-light-bulb-pack-of-4_p343020
The problem I am facing in finding a replacement is that they are all 12V only, not 220-240V. (Robery Dyas, screwfix)
(I believe such bulbs are typically used in cars hence 12V).
I am not well versed in electrics - I presume a 12V version won't work and I need to find the right one?
(there is no print of the spec on the bulb I removed to check if it was a 220-240V one.
