£200 not sure where you're shopping?! The D610 is selling in £5xx range.
Think he's saying the D610 sells for £200 more than the D600.
I've only seen them from ~£700+ on wex/mpb/lce. Be keen at £500 but that more sensibly seems like D600 territory from my search this week.
Thanks @ddoubleep good to have a positive recommendation on the 35f/2.
The f2 IS is a brilliant piece of glass I very nearly went for a used a sigma 35mm f1.4 but I'm glad I didn't this size and weight of the f2 fits my usage perfectly.I really like the idea of the 35mm IS f2, it looks great but the 5Dii and 6D seem more expensive like for like compared to the D600 which looks to be the better camera.
The sigma 24-35mm f2 also looks really interesting, bit expensive for just dipping my toe though.
I think I’m fairly settled on a D600 and a 35mm f2D now.
I can totally understand going Nikon if I was starting over today I would particularly with that generation of kit as canons sensors fell way behind!
Totally agree since canon out the ad conversion on the sensor the gap to Nikon/Sony is nothing like it was. That's not to say you couldn't get an amazing image from a 5D II/III the reviews always seem to miss the bit where the photographer makes the biggest difference great dynamic rangecwon't make a crap photo good!5D4 sensor is up there but the rest the of the range is a bit meh.
