- 24 Mar 2018
- Brighton
Hi all,
New here!
I would like a bit of advice on vrm cooling for two machines that I am building, one has a gtx 1060 and the other has a 1080 both seem to work well with Alpenfohn Broken 3 coolers overclocked using 1800X 3+3 40X (or 4+4 39X) at around 1.375 volts (1.365 idle measured at the vrm caps) and 1.315 under load High LLC. I'm not brave enough to poke around the back of the CPU while unsure where to test properly.
CPU temps under full load top out to around 70c running 8 core @39X and 60c for 6 core @40x
I'm using/testing with a 90mm fan side on to the VRM Soc which seems to bring temps down about 10c from 70+ full load down to around 60+ full load. I'm sort of thinking of using 2 small 40mm fans at around 5000 rpm strapped to the vrm soc, is this an idea that will work or should i try to fit a bigger fan top of the case blowing down ?
I did look at the water block for this board but my budget wouldn't allow for a loop + VRM/CPU block sadly.
Open to any ideas for any other type of vrm air cooling solutions
New here!
