- 15 Mar 2018
- Scotland
So i got my new cooler today and GFX card, got it all set up eventually (the usual post build, but it wouldn't actually post drama occurred) and once i did a clean windows 10 install and upto date drivers, I turned my attention to the overclock.
As above i am running at 4.5GHz with 1.35v, with my ram voltage set at 1.35v with the speed and timings manually set as well, speed step is turned off and LLC set at 50%. I am running this on a Asus P8Z68-V/PRO and the cooler in question is the Corsair H100i V2 in a push/pull exhaust config mounted in the roof of the case
I am running a stability test in Aida 64 and my max temps are sitting between 59 & 62c, but the actual temps, as reported by both Corsair link and core temp are varying between 50 and 60c depending on the core.
So the question is, is it likely this is caused purely by problematic thermal paste application, hence the inconsistencies across cores or is it likely caused by the manner in which Aida 64 conducts its stability testing?
I ill be honest and say I had issues getting the pump mounted which absolutely will have affected the pre-applied compound, but there did seem to be a reasonable and consistent covering.
