- 22 Oct 2012
- The Moon
Hi everyone,
I've just ordered the 8700K for a new system and wanted some advice taming the chip which is meant to run pretty hot. I have the Phanteks Evolv ATX which received excellent reviews and looks stunning. However, the analysis didn't outline the case's poor airflow leading to higher thermals. In hindsight, it's going to happen because of the closed aluminium panels.
Ideally, I'd like to keep the case and require hints of which cooling path will be optimal. Should I opt for a Noctua NH-D15S air cooler, or mount an AIO. Been reading the AIO up top is a bad idea as the air just circulates around the remoavable mounting bracket.
Please note, I've installed the original 3x140mm Phanteks fans. One at the back and two in the front.
