New motherboard need some advice
4 Apr 2018
Hi everyone am new to the forum today :) so yesterday I bought Asus ROG Strix B350-F Gaming AMD B350 (Socket AM4) DDR4 ATX Motherboard of overclockers to start my new bulid been 7 years lol anyway I only play world of warcraft that's the only game I play on pc am looking for advice on a cpu and gpu as it's only world of warcraft i don't need a titan gpu or a threadripper cpu for wow what do you guys/gals think I should go for to run it as high as possible thank you in advance wullie
On the assumption you are playing at 1080p I'd go for something like this:
My basket at Overclockers UK:
Total: £647.05 (includes shipping: £11.10)​
The Ryzen 5 will do you just as well as a Ryzen 7 when it comes to WoW.
You only need 8Gb Ram for Wow, 16GB would be a waste.
A GTX 1060 will do you nicely with everything at Ultra.
Highly recommend an SSD for your Windows install and WoW.
Obviously if your budget will allow, you can upgrade to higher performance components for some future proofing, but for now this sort of spec should thrash WoW without a sweat.
Thank mate I will be on a 27 inch Samsung gaming screen 1920x1080 thank you everybody for the help
New Expansion - now taking advantage of Threads!
https://eu.battle.net/support/en/article/137431
Intel® Core™ i7-4770 or
AMD FX™-8310 or better
NVIDIA® GeForce® GTX 960 4GB or
AMD™ Radeon™ R9 280 or better
8 GB RAM
70GB available space SSD
Total: £495.06 (includes shipping: £11.10)​
if you can push gtx 1060, then great
Thank you mate
And yeah, Google ryzen 160 Vs FX 8350 .. specially at 1080p any range of card.. pulls away nicely !
Might be nice to splash a bit of Night Hawk 8GB RGB ram to go with the Strix board ;)
Seeing now they are Ditching DX9 for other games , wondering how long it'll be till they drop DX9 support for WoW - this expansion seems to be a big push for graphics and coding updates
the nuclear is really nice came yesterday without case the rgb would be nice on it lol yea that's one the reason am guiding a new pc for wow 7 years ago I bulit my last on wow this day I can only run at 4 out 10 on the setting screen lol
damn, rgb only for 16gb with 3000hz/3200hz + kits :(
SSD should cover you for windows- and future expansions for a little while
did you need a new case? if not- recommend looking at phanteks Halo RGB Fan covers :)
fans should plug in straight to the mobo :D
i think they now also do RGB COOLER!
https://www.overclockers.co.uk/cool...-cooler-92mm-mam-g1cn-924pc-r1-hs-07q-cm.html
ryzen 1600 doesnt need a huge afermarket cooler to keep it cool to push past 4.7ghz OC but does look nice!
Yes one the reason I went for that case I've already got a cooler master cpu cooler
https://www.overclockers.co.uk/cooler-master-master-air-rgb-ma610p-cpu-cooler-120mm-hs-07r-cm.html
Probaly a bit over kill but rgb for that awesome case
ah nice! should handle 2.8/9Ghz overclock of ryzen chips nicely and looking pretty! cant remember how many RGB headers the strix board has or if the case fans have Y connections on them to chain them up
Has one on top and one on bottom of board and one bedside cpu cooler am sure it has but come with cables needed to split if I have to
