Fury X for £330, do I buy?
23 Nov 2013
Manchester
currently have an r9 290, i have the itch to upgrade and have had for a quite some time but refused to pay stupid prices. There’s a Fury X on the well known auction site for £330.
Is it worth buying? Is it worth the upgrade?
I game at 1080p, but mostly play VR now
Cheers
No, well, I wouldn't anyway. Now that prices are falling, wait for a 1070 or Vega 56, they will be much better at VR.
If you can hold on until after Nvidia's event in May, it might be worthwhile.
I've got a FuryX sitting in the cupboard and I'm not even sure I want to switch out my GTX980 for it (not sure how much difference there is in a 980 and 290 these days).
A FuryX would be slightly better than a 980. I had a Fury Nano which benched a few % higher than the 980.
Had a FuryX, out of the 40+ cards i've owned this was one of the most disappointing, was glad it broke so i could RMA for a refund.
Yeah, but there's a few additional factors for me.
First, I'm running my second monitor at 1440p/60hz over DVI. FuryX doesn't have a DVI port, it does have an adaptor though, but I'm not sure AMD will allow me to run the monitor at 1440p/60hz.
Also, I've actually got 980 SLI, so there are a couple games that it works in and I get a nice boost in. Not as many games as I'd like to be fair. Also the 4GB can be an issue that SLI doesn't help with.
It will work if the adapter can handle the resolution. There is nothing on the GPU side that would prevent this.
My 290X wouldn't do it, that's what concerns me.
Well, when I say wouldn't do it I mean didn't give the option, just 1080p/60 or 2160p/30. I have since learn't that you can apparently create custom resolutions in the AMD control panel, not sure if that will fix it.
This is getting a little off topic though.
It was a limitation with the 290 cards when you had two 1440p (or higher) monitors connected to the DVI ports. It scaled down the resolution on the second one. It's not a display port limitation so it will work fine as long as the adapter works.
Good to know, thanks.
I may switch them round and give it a try.
I had a non X fury and it was pretty decent, but of course the 4gb ram did hurt.
I wouldnt buy an X at that money, it wont be too long (hopefully) before V56 is back down to near its RRP and well.... there is no contest there - thats the card to get unless you want baws to the wall 1080ti performance.
A fury X is a £250 card. Sits in between a 1060 and 1070 whilst being older and consuming more power.
I've been using mine while my vega64 is being RMAd and I've been pleasantly surprised how well it still does at 4k.
I also want one, but won't go above £250 for it (I already have a watercooling bracket for a Fury X).
Most of the ones I see are Gigabyte/MSI/CP- didn't Asus make some as well?
