I'll be hooking my PC up to the TV and mainly using windows desktop/apps, so even with the static taskbar etc., would you guys still recommend OLED for this use?
My current TV is often left on for a couple of hours or more displaying the same static content.
Yes unless you are going to have the same static image displayed for hours at a time.
Just purchased the LG 65 C7 (for the black rim) from RS. Arrives Tuesday and can’t wait. I did a lot of research and concluded that this was the best way to go. Liked some of the 1500 Samsung’s TV’s but in the end OLED won.
WOW - if this is the pinnacle of OLED technology, pleased I gave it a miss.OLED is at its peak now don’t think it will get much better.
Well really it is - as I highlighted earlier, there is a lot to take into consideration.IT's not really that hard.
If money is your primary concern get the XE93.
If you want the best TV and can afford the £1409 buy the LG B7.
Best PQ available since plasma. No haloing/bloom. Fantastic veiwing angles.WOW - if this is the pinnacle of OLED technology, pleased I gave it a miss.
how many people have actrually tried the two adjacent in their home conditions ? (buy two send one back)sure a top end LCD looks great but compare it to an OLED and it just pales big time in comparison,
hopefully they do not change the static logos.Now that red has been exposed as the subpixel color most prone to differential-agibg-based burn-in due to static logos of CNN and MSNBC as well as bright yellow HUDS of some games, it appears that LG has understood that thecred subpixel is at least as vulnerable as the blue subpixel (which is rarely used in static elements).
Because it’s a Currys exclusive they can’t advertise it but if you call you can order it from them. It’s better as the rim is all black rather than silver so much better for wall mounting.Was this purchased in store? Can't seem to find it on their website.
Ended up getting the B7.
So good so far. Any recommend setting for the tv?
