Good to know, thanks.
I may switch them round and give it a try.
You are welcome
I tried the adaptor that came with the FuryX (connected to a 980) and it seems it will not support 1440p/60hz. It does 2048x1152/60 or something like that but that's not really what I'm after. I'm only using it for my 2nd screen, but still. not worth losing the resolution just to gain a few fps in some games.You are welcomeAnd I don't think we are taking the thread off topic, it was finished anyway
it's a unanimous NO, don't buy a Fury card for £330!!
EDIT: Possibly also worth mentioning that I occasionally use VR (Rift). Not sure how FuryX compares to a 980/980SLI in VR? (I know the newer Nvidia cards do better than the newer AMD ones, not sure about this Gen though)
For £330 a 980 Ti is a much better bet, consistently faster and better at VR.
Don't do it. Trust me, don't do it..
I am running one. It's all well and good, until it runs out of VRAM. Then it turns into a slideshow. It didn't have enough then and it certainly doesn't have enough now. And the main issue with it is that at 1080p (where it just about has enough) it leans so hard on the CPU that you need a top end one. Ironically when you turn up the res and settings it starts to shine, then it runs out of VRAM
I installed FC5 recently on the rig (it's all fully WC with 480mm of rad space) and the mins at 1080p were actually worse than 2560x1600 using VSR on a 1050p monitor (16:10) however it then became very thin ice trying to tune it so that it would not go into HDD streaming mode (how they fixed it running out of VRAM, it used to just black screen and reboot the PC) and start using the paging file.
I got there in the end but it was way too much sodding around. Get a 1070, 980Ti or a Titan XM. At least you will have enough VRAM. I have had mine since launch (bought from Gregster) which is why I have not replaced it. I have it in my second rig.
Wired as the FuryX seems to out do the GTX980Ti as you increase resolution. Seem to remember when you could buy an EVGA 980Ti SOC new for £260, that the Fury X was the card to go for at high resolutions.
It definitely improves, but as I said you then have the problem of VRAM. In games that don't use all of it it does very well, but those games are few and far between now. ROTTR for example just brings it to its knees. Certain levels of BLOPS III do too.
My brother has a Fury x and has none of these problems. He plays on a 1440p monitor and hasn't complained about FC5 or ROTTR. Mind you he only got ROTTR last year and plays in DX12 only.
ROTTR hates this card. At the time of launch I was running two, and the game used to go into an audio loop and crash the PC. So I removed one, tried again. Same issue. Turns out it was running out of VRAM and just crashing. That was at launch... The same issue used to happen on certain levels in BLOPS III too. Then AMD come out with a statement to say they have fixed the issue. So I retest.. Firstly in BLOPS III I deliberately load up the level. It starts off fine, then it drops down into the low 20s. Then I notice why.. It is using my paging file. So it uses the same method Nvidia were using years ago, which they called "Texture Streaming". They first did this for BF3, because most 1gb cards did not have enough VRAM. It kills the game and it kills you with the worst input lag EVER.
I monitor VRAM use when I game. I have to, I do not want to play at 20 FPS. Far Cry 5 was quite easy, but do bear in mind 1600p is higher than 1440p. Thus it will need more VRAM. I can't even play Fallout 4 on the card really. Well, not at acceptable levels. As soon as you go over 1080p on the latest release of FO4 it runs out of VRAM.
There are games that run fine on it of course. Games that are not VRAM heavy. Problem is most releases these days are VRAM heavy. 4gb was a talking point when the card launched. At time of launch it was quite easy to over run the VRAM buffer just using Shadow Of Mordor. AMD led us to believe that the speed of the VRAM and bandwidth would alleviate the lack of it. They lied.
It's a shame, because if the card had 8gb VRAM it would be problem free. But it isn't, and thus is not worth buying IMO. I would rather buy a brand new 1060. Not as fast overall, but has more VRAM and will therefore have less issues.
£330 for Fury X?
No way you will pay £330 for 3 years old second hand Fury X! Why would you pay that much while people bought second hand GTX 980 Ti for £150, second hand GTX 1070 for £250 on sold listing.
Second hand Fury X should cost less than £150.
