ASUS ROG Strix XG32V or Acer Predator Gaming Z321QU bmiphzx
18 Oct 2002
Aberdeen
Does anyone have any experience of either,
Ive got a 1080ti so I'm leaning towards the predator, but i don't want to splash out 650 notes on a monitor when i can't find any reviews, the Asus, on the other hand, is kinda cheaper and looks ok, but no g-sync
does the Asus Rog allow Nvidia cards to run it @144hz also in the comparison i found a cheap AOC monitor for 400 quid that is kinda similar specs again not sure
i don't want a widescreen. anyway any help would be appreciated
Asus Rog
31.5" WQHD (2560 x 1440) 1800R curved monitor with 144Hz and Adaptive Sync/FreeSync for immersive, smooth gaming with DisplayPort and HDMI connectivity
  • 31.5" WQHD (2560 x 1440) 1800R Curved Widescreen VA Display
  • NVIDIA G-SYNC Technology
  • Refresh Rate: 144Hz (Overclocking to 165Hz) - Using Display Port
  • Ports: 1 x Display Port 1.2, 1 x HDMI 1.4 & 4 - USB 3.0 Ports
  • Display Port, HDMI & USB Cables included
https://www.displayspecifications.com/en/comparison/9c325217a
Asus Rog
You said you don't want a widescreen but all modern monitors today are widescreen,
Here is link about 'Nvidia cards to run it @144hz'
https://linustechtips.com/main/topic/836067-1080ti-overkill-for-1440p-144hz-gaming/
I have a Acer predator XB321HK cost me £715. it is a nice 32inch 10bit panel IPS screen with Gsync 3840x2160 resolution But like all Acer predators there is a Gsync module problem in the monitor it was reported back in 2016 on the acer forums, I sent it for a repair it's now been with Acer for 10 days and still waiting think twice before buying Acer I learned my lesson.
to Answer you question on the Acer Predator Gaming Z321QU there is only a few reviews online I have seen and the price £476 but I can't post the link on this forum.
GTX1080 TI nice card I had the same until it went wrong got my money back but now have to buy it again this year.
to Answer you question on the Acer Predator Gaming Z321QU there is only a few reviews online I have seenhttps://www.newegg.com/global/uk/Pr...m=N82E16824011187&cm_re=Acer_Predator_Z321QU-
thanks for that, I'm gaming on a free sync monitor at the moment on this GeForce card no problems, looking at the reviews I'm gonna go for the AG322QCX it uses a modified Samsung panel the same one as in the Asus. save me some dosh and get that.
Gsync is all just hype market crap, I should have gone for a free sync monitor from LG, and save over £135 myself I never buy Acer again, I had the GTX1080 TI xtreme edition nice card but it died on me now I have to buy another on todays prices.
Ended up getting Aoc Agon AG322QCX for £400, very nice monitor needed a wee bit of tweaking, no dead pixels so that was a relief. 144hz is amazing playing FPS games, my 1080ti tears through it @ 1440p. Anyway thanks for your input Aorus...
I been looking for a 32" GSYNC monitor. Came across this post, do the freesync monitors work ok with Nvidia cards? namely the 1080tis. The price difference is crazy compared to the GSYNC variations. I mostly do motion graphics and play FPS games.
Was going to go for the Predator Z321QU for £640. But £400 freesync is tempting if it doesnt make much difference.
