Need a new desk
1 Nov 2007
England
I'm moving at some point soon and need a new computer desk. My current one is OK, but it is a bit small. I currently have 1 27" monitor and 2 24" monitors on it but what I want is to replace the 27" monitor with a 32" 4k monitor, but it won't fit on my current desk.
I don't have much cash to spend, so I looked at the Ikea website, and they all seem somewhat small. What do people do when using multiple monitors that take up so much space?
I've seen monitor mounts but not sure if that is the right solution for me.
Anyone know a place to get decent sized computer desks (draws not needed)?
My screens are wall mounted, centre/main one of a fixed mount and secondary screen on an arm. Frees up a huge amount of space and allows adjusting monitor position if needed (to get a nice angle for working etc).
Desk is an oak worktop (worktop express) cut to the size I wanted. 2x2 baton on the 2 walls its against (screwed into wall and then worktop screwed down to it) and an adjustable leg on the free floating front corner. Circular saw to get the size you want. Went to the trouble after getting it the right size of removing it all and spending the time to oil it properly (teak oil). really really nice finish after doing that, and wasnt hard to do.
Plenty of guides around on how to do this, and it really is a nice solution!
Don't answer this question if you don't want to but roughly how much did that all cost you?
Ha, no worries. It was cheaper than a nice desk ;) All prices are approx/from memory.
Screen wall mount was about £20 (for a 32" screen), arm mount was less (£10 - BPS Tilt & Swivel TV Wall Mount Bracket) from Amazon. 2x2 is cheap, £10. Leg was £20 ish. Screws/rawl plugs etc I had already but again, not a lot.
http://www.worktop-express.co.uk/wood_worktops/oak_worktops.html#sizes-prices
3m oak worktop: Oak Worktop 3M X 620 X 27mm £130.00
3m is a huge desk, get your tape measure out... 2m would do most needs but when I originally did it I had a 2.4m gap (surrounded by walls on 3 sides).. Since moving I took it with me and simply added the leg as its only got a wall on 2 sides.
I also fitted 3 desk wiring hole things (round hole, nice plastic trim, rotatable cover to hide/let cables through). 1 in each corner and 1 dead center. Makes wiring much neater/easier as the desk IS hard against the wall all the way around.
3m should be possible under £200. 2m should be under £150ish
Not cheap, but not silly money either. And the end result is a really nice desk that is exactly the size you want and when I have friends over I do get asked where I bought the desk... :)
And if you want even cheaper, look at laminate. Not quite as nice as real wood, but:
Oak Block Laminate Worktop 3M x 600 x 38mm £60.00
Hard to ignore the fact that its under half the price....
Worktop is definitely the way to go. Mine was only small to fit in the end of an L shaped box room so under 1.5m wide but I went for 40mm thick laminate sitting on batons on 3 sides so no legs. Looks the part, does the job perfectly and cheap too.
Awesome. Thanks for the tips guys.
I was half thinking of putting something together with MDF but thinking about it laminate would look a lot better.
Worktop is definately the way to go.
I went with Ikea parts - Two sets of Alex drawer units and Ikea walnut kitchen worktop. Along with a cable tidy, it came to around £200 for the lot. Desk is 2m wide
Yeah I'm going to be doing this - converting small box bedroom into a study and having the desk the full width of the room.
@samcat how much cutting did worktop express do for you? I don't remember if it was them or another company, but I got the impression you could send them a schematic and they would do all of cuts?
@Goksly - I did all my own cutting. Easy enough as I just wanted to shorten the length. Careful measuring, pencil line and Circular saw.
But if your not comfortable with that they do offer a cutting service:
http://www.worktop-express.co.uk/laminate-kitchen-worktops-cut-to-size
Great company, have dealt with them a couple of times and always been happy. :)
For mounting the batons, invest/borrow a laser spirit level or a long spirit level.
Mount the baton to the wall in a couple of 50-60 cm lengths. Work out the height you want the worktop to be.
Take a tape measure to your current desk if thats about the right height for your chair/working, measure from a fixed point where you know your gonna be consistent, top edge of skirting running measure up a wall for instance, rather than carpet in the middle where you might be at a funky angle.
Note down the height. Deduct the thickness of the worktop, thats the height you want the TOP of your batons.
(Assuming batons are 50mm x 50mm, you want the screws to mount them half way up, so deduct another 25mm. This is your 'drilling holes' height, but will be irrelevant for this method)
Measure up the same edge you originally measure and mark it at the TOP of baton height you calculated earlier (bit of masking tape and a pencil works well if you dont want to mark the walls).
Laser spirit levels are cheap(ish) and great for this next step, mount on a tripod and adjust so that the horizontal laser line runs across the mark you made on the wall. Wander around and mark this line in a number of places (just go around and roughly every fist width put a dot with a pencil.)
Assuming you are mounting into a U shape (3 supporting walls) - Cut your baton into 2 lengths that do the edge of the desk (dont do full length, plan to not come all the way forward, leave 10-15cm, and cut off at 45 degrees to make it look less blocky, avoids smashing your knee into it!). If only supporting on 2 edges (1 long and 1 short) then you only need 1 edge piece.
Cut the pieces to support the long edge, roughly 50-60cm long is fine (makes it easier to handle). Offer up/do the maths and if one needs to be longer/shorter so be it. Wont matter if the worktop is not supported all the way around, so long as its mostly supported.
Plan to leave a gap dead center (assuming thats where the screen is going to go) as it makes it easier to drop the cables down as tight to the wall as you can.
Number your pieces, 1-6 (or whatever), from left to right... So 1 is an end, 2-5 are long edge and 6 is an end. Draw an arrow to show which way up they go.
Get your drill out and (with a wood drill bit thats the correct size for the screw to just about fit through) drill 2-3 holes in each piece, roughly middle and then halfway between the middle and the ends. (I overengineer everything, and have stood on my desk a couple of times...).
Put a masonry drill bit in thats the same size as the wood drill bit you just used.
You may want a friend for this next bit.
Offer the first piece up, paying attention to the dots you made on the wall all being just visible and a consistent distance from the piece. Hold it there and DONT MOVE IT.
Drill with the masonry drill through the holes. Doesnt need to be deep, this is just to mark the wall to show where to actually drill.
Rinse and repeat all the way around with the different pieces, keeping the numbering/order and way up correct.
Swap to the correct size masonry drill for your rawl plugs/plaster plugs, drill the holes and put the plugs in (rawl plugs want to be a bit tight, plaster plugs follow the instructions).
Electric screwdriver time (or tired arm/wrist time) Screws for the plugs, as above I usually overengineer to these tend to be good size and long, 80mm or so (as going though 50mm of baton). Put in, do up loose... Repeat all the way around, keeping it loose.
Spirit level on and check as you tighten, usually a bit of wiggle room!
Worktop will sit on easily if being fitted against 2 walls... if going against 3 walls it can be a bugger and will probably need fettling to fit. Electric plane and a strong friend will be required, as you will be taking it down stairs and outside to plane it... Makes a HUGE amount of dust/mess.
Once its fitting nicely (you want it to drop into place, NOT have to hammer it home... Trust me, been there... Had to cut it to remove it!) drill some holes up through the batons, just long enough to go through but not into the worktop, put some screws in that are longer than the baton is thick and do them up to secure it. Its not going anywhere, but this is just for extra safety!
If mounting on 2 walls and with 1 leg then make sure leg is adjustable and can do the length you need. Follow instructions and mount it. Securing is MUCH more important when its only supported on 2 walls by batons.
Sorry for the essay, but a bit of a step by step seemed wise as have done it 3 times!!
If in doubt, stop and ask for guidance/help.. No point messing it up!
Thanks for the write up. Ordered some samples from them and another site... so will see whats what. I'll be mounting across full width of room, but will probably put two legs on as both my computers will be under the desk and certainly don't want them being wiped out ;)
Laminate or wood?
If wood and its coming naked (untreated), get some danish oil/teak oil to see what the various finishes look like once oiled, makes quite a difference to how they look and really makes the surface 'pop'.
For laminate, get down to B&Q and have a mooch at the various finishes, will give you a good starting point of what you like. :)
Be sure to share on here, love a build thread!
Laminate - furniture currently in the room is white stained oak so I'm going with that. Will wait for some samples to come through and then yeah nip to themlocal B&Q and see what's what. Will update picture as and when I start... Which will be next few weeks hopefully.
Sounds good samcat, would you mind posting a picture of your finished desk for inspiration?I'm thinking about ordering from worktop express, either a right angled oak worktop or just a standard straight worktop to fit between a wall and chimney breast.
