CAPTIAs and visual impairment
10 May 2004
Sunny Stafford
Ignore the big fonts and dark theme. Does anyone else find CAPTIAs discriminatory? I'm blind in my right eye and my left eye takes a -27 lens. Most prescriptions for contacts are in the -1 to -7 range and -5 is considered bad.
Anyway, Google's playing up. I'm not a robot, so I tick that box.
Which are these are street signs? Surely I answered correct with the 4 boxes I ticked but it's coming back as not correct.
Then it repeats the street signs question 2 more times with different images, again coming back as incorrect.
Finally, it asked which of these are roads? But I can't see a road in any of these!
I'm not looking for answers for the questions because they time out after a minute or so. Just wondered if anyone share these woes. Other sites will do this occasionally as well as Google. I did think that a VPN may have caused this but it's turned off at the moment. Might just be a temporary glitch with VM.
I don’t have a visual impairment but this happens to me as well, click all squares with a car, I click them and still get a second one.
Smh
It’s called captcha by the way
Are you using a VPN by chance? If you ever try and beat a captcha whilst using something like Tor you usually have to answer the question several times.
Do you have a Google account and are you signed in? If I'm signed into my Google account I'm "trusted" and only ever have to check the checkbox which makes it far easier.
I guess your black text has hidden it, but at the bottom left the second button is an audio challenge instead of a clicking challenge, it may be easier:
I do have a VPN, but it was turned off when I tried it earlier. It's an intermittent problem that happens once in a while. I certainly don't use TOR. Whichever way, it seems I'm not alone!
Generally with a not a robot box you can move the mouse around over the box a few times before you click it and the verification doesn't appear. On a phone just touch the screen near it a couple of times.
also an interesting vid on the history of these evil creations
That explains why I always get the image recognition captchas - Google can't track me reliably enough to know I'm the same person who did it last time. Which is a good thing (and quite surprising).
Could also be the possibility of a false negative on purpose for an extra hurdle. So you might get it right but there's more than one to pass.
