- 11 Mar 2013
My bt hub isn’t working. What a better replacement
BT should replace it shouldn't they? Otherwise I use a Netgear similar to an ac1750 - not quite sure of the model.
Andi.
Budget often helps when you’re looking to buy something...
Airport Express & Extreme are very old now and lacking in a lot of features.
Yes they should. but there router is crap. Wanted something a little better
