I have a 1950x with an Enermax LiqTech TR4 240 cooler for it. I have push pull fans setup on it.
I am getting what seems like very high temps with a slight overclock 3.9ghz and moderate volts 1.33
Rendering 4k footage using 80% cpu load on all cores
Mobo is Asrock Taichi and I used the grizzly compound for the TIM.
How would you know if the cpu watercooler is not working properly?
Could I have the load line set too high?
I havent changed many settings in the bios
The rad feels cool, but there is a ton of heat coming off the pc so its being cooled somwhat
I am wondering if I need to replace the 240 with the larger 360 or if its blocked or something
Thanks for the help
Thanks for the help
