OcUK Staff
- 26 Nov 2014
- Stoke
Launching today we have the extremely popular Phanteks Eclipse P300 Glass in 3 new variants - White, Black/White and Black/Red. Since it's launch, the P300 has proven to be an excellent entry level model for the Phanteks range, combining an attractive look, good features and extremely competitive pricepoint. Adding colour variants to the P300 makes complete sense in that respect, to bring the case in line with it's bigger brother, the P400S Glass. The P300 colour variants keep all the features available on the normal P300 model, including a tempered glass side window, RGB strip on the PSU shroud, 330mm VGA support, E-ATX motherboard support, up to 280mm radiators on the front panel and more. There's even support for Asus Aura, MSI Mystic Light Sync and Gigabyte RGB Fusion, allowing you to control any attached Phanteks RGB products through their respective software suites.
All 3 variants are in stock now and available at the same pricepoint, which is a bonus considering the white variants of cases generally cost a little more to produce!
Phanteks Eclipse P300 Glass Midi Tower Case - White @ £54.95 inc VAT
Premium Midi-Tower from Phanteks in white, Tempered glass side window, Pre-installed 120 mm fan, Power supply shroud, Integrated dust filter, LED lighting, 2x USB 3.0
Only £54.95 inc VAT.
ORDER NOW
Phanteks Eclipse P300 Glass Midi Tower Case - Black/Red @ £54.95 inc VAT
Premium Midi-Tower from Phanteks in black and red, Tempered glass side window, Pre-installed 120 mm fan, Power supply shroud, Integrated dust filter, LED lighting, 2x USB 3.0
ORDER NOW
Phanteks Eclipse P300 Glass Midi Tower Case - Black/White @ £54.95 inc VAT
Premium Midi-Tower from Phanteks in black and white, Tempered glass side window, Pre-installed 120 mm fan, Power supply shroud, Integrated dust filter, LED lighting, 2x USB 3.0
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
