20 Apr 2018 at 20:05 #1 pcfarrar pcfarrar Associate Joined 6 Jun 2016 Posts 1,839 Are there any Windows 10 SATA drivers for the X470 or do you use the stock Microsoft drivers?
20 Apr 2018 at 20:17 #2 opethdisciple opethdisciple Soldato Joined 18 May 2010 Posts 23,677 Location London pcfarrar said: Are there any Windows 10 SATA drivers for the X470 or do you use the stock Microsoft drivers? Click to expand... Should be listed on the AMD drivers page.
20 Apr 2018 at 23:06 #3 pcfarrar pcfarrar Associate OP Joined 6 Jun 2016 Posts 1,839 opethdisciple said: Should be listed on the AMD drivers page. Click to expand... Only seems to be RAID drivers. I will have another look.
21 Apr 2018 at 00:31 #4 HeX HeX Soldato Joined 20 Jun 2004 Posts 12,023 Location Huddersfield, UK If it's like the x370 you need to manually point it at the AMD drivers folder as the chipset installer doesn't do it for you for some reason.
