Thankfully not - the 5V is just used for logic.
The 12V supply powers the stepper motors/heated bed/extruder heater - even the RGB lights are 12V.
Looking at this I should be able to get away with 500W if it's actually 500W and not just a sticker - even the CX500M has 38A on the 12V rail.
Logic circuitry uses likely dozen or something like that watts.
And with that bundled group regulated archean fossil done cheaply cross load might make even that 5V vary.
I mean -5V rail was removed from ATX specification in 2003!
Corsair CX is standard cheap capacitor PSU, instead of quality PSU.
Also with group regulation it's not the best in keeping voltages stable during cross load.
Modern DC-DC PSUs are lot better for that with 3,3 and 5V made from 12V by smaller step down converters.
Bitfenix Formula is cheapest with quality capacitors.
https://www.overclockers.co.uk/search?sSearch=bitfenix+Formula
For some reason they use platform with actually current limited wire groups, but anyway single one of them no doubt gives more current than that crap.
https://www.techpowerup.com/reviews/Bitfenix/BF750F/4.html
For modular cabling Seasonic Focus Plus Gold is cheapest with quality capacitors. (and crazy level voltage regulation)
https://www.overclockers.co.uk/seas...plus-gold-modular-power-supply-ca-05p-ss.html
I don't think any below 80+ Gold efficiency PSUs have DC-DC design and in fact there's only one 80+ Gold cheaper than Bitfenix Formula.
Cougar made by mediocre HEC with quaranteedly cheap capacitors.
Oh geez I made the mistake of looking inside - I didn't know they actually got crusty.
Where are those "nude" shots?
Or was everything buried in too much dust to distinguish anything?
Those tiny undersized parts of cheap craps could do that easily.
And what's with another few minute power cuts...
Guess I have to have flashlight nearby when going to shower.
