So, I'm looking to get a new SSD & upgrade my memory, my current specs below;
Intel Core i5-4670K 3.40GHz (overclocked to 4.0 GHz)
Gigabyte Z87-HD3 Intel Z87 (Socket 1150)
Seasonic G series 550w '80 Plus Gold' PSU
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3
Gigabyte G1 Gaming GTX 1080
Windows 7 Ultimate 64
Any particular RAM you guys would suggest? My motherboard doesn't support DDR4 so I'd be after 16gb (2X8gb) or perhaps 32gb (2X16gb) DDR3 depending on recommendations for future proofing, baring in mind I'll probably build a new system in a few years so pondering whether 32 is worth it~
I'm also wanting to get a new SSD due to needing more space, I currently only have a 250gb SSD (Samsung 840), I'd like to stick to the Samsung line of SSD's but unsure which one to go for. I do want whatever is the best price/performance however and would like 1TB storage.
As to the "worth it" of memory re: 16/32gb, I mostly use my pc for gaming at 1440p though often while doing so have a bunch of other things open (skype, discord, multiple browsers) and am possibly either streaming or recording via obs studio.
I say I'll probably upgrade in a few years but really that comes down to when I feel the need to upgrade to a combination of 4k res, nvme ssd, ddr4 ram and new gen cpu - so probably quite some time into the future
Lastly, when it comes to installing RAM would it just be the case of taking my current sticks out and installing the new ones or would I have to set timings etc in bios? Note that while my cpu is overclocked the memory is running at stock
