Best way of leveling manhole cover
27 Mar 2013
So in my garden i have a manhole cover on the path (hopefully pics work). Its a bit wonky due to the ground around it not being level and the kids somethimes trip up on it. Whats the best way of leveling it, raise the surrounding concrete or is there an easier way?
Cheers
y4mf78bClY8RqImSKm_Hulvsat4W1p08saKKFtEKf5r9-4wvUThFAg27yiS4HcHHZ-fDHtu1LTDZVmPy0_S1aQvrM7dfz9AtjlxlLRYdWj5b7z37po57HYid2St-BSvpPheez_WzPmKUQIIhX8XeASDrk6XBACimc33RACmz7m-HzdXlxx5qsDmW37EvO23tBfBpugKVFrnW1WD0YoXbTxkag
y4myACDlBe_7PaaQANyCirb2Q71NfDLV9snOUOINuFUf8QXUOMdyhJ6RCSPoQ5DlsD2KT1gMVkUCTE7CIF3Iv2VhawZHIeSPZjO3jfCDDqh5ayusIbwoJTlJL6gfYdhEIxsdKwfpmGvdlLD8Sl3FQLwh5YfylKf7HGVvkkRILGJhFvLJ28lMGRtUpXPXoQTr6kgdaJbRfyhNJgP3ZHvjJsciA
That to me looks like it's not sitting in the collar correctly. Have you lifted it up and cleared out the ring that it sits in? It may be full of stones and crud.
You will have trouble trying to level the concrete as it wont be thick enough and will just crack and flake off. As said get a spirit level across it and see what has happened.
Is it a modern all in one inspection pit or is it a brick hole with the ring sat on top?
Find out what has bowed and work from there. The cover should fit snug on the ring. You might have to replace all the concrete or just the one half to get the concrtete thick enough to hold its own.
If that slab is the size of the chamber underneath I would check that for cracks inside aswell. Im also wandering why the slab next to it is so out of level with the cover slab.
Failing that. I see it is cracked near the slate aswell. if that is soil under it you might be able to dig down under the concrete and wedge it up and pack it somehow.
Are they not tripping on the edge of the slab rather than the cover?
I'm not sure exactly which bit they are tripping on, there is a mix of concrete and large pavers (which i think are either side). I would say that theres not many where they are the same level as the next one. I'll check under it this weekend but i won't post internal pictures due to whats under there.
