Lool I have one as a courtesy car atm.. it wasn't me thoughYeah a Ford Kuga for some reason?![]()
Embedded them all for you buddy, looks better than just links!![]()
Can't beat the Subaru burble lol
Also what happened to that Civic in the last video? A failed gear change or something
It wouldn't go into second
I'm surprised I got it back up to 111mph at the end of that one though. My best was 13.3 at 112mph I think.
I want the EcuTek RACEROM Bluetooth module before I go again, firstly so I can fully disable traction control and get the AD08Rs spinning and pre-start. Then increase traction control a touch more than what it's on now to try stop the 1st/2nd/3rd spins
I did try easing off then back on a couple times on one run to try and get traction back but it just wasn't happening.
Nothing went wrong with the Civic, that was in fact the fastest run of the day, My 530HP Corolla just trounced it.![]()
Ah didn't realise it was someone from here! You have supercharged it right? Was a bit perplexed at those numbers at first![]()
it's turbo'd. safe 420 / danger-to-gearbox & uprated-fuelpump-needed 510 bhp maps.There's a lot more to come from yours if you get it dialled in.
I'd say there's easily another 5-8mph possible on your trap speeds. 111mph was what I was trapping with close to 200bhp less
@ReAPeR101 @Plenty O'Toole Is it OK if I slice & dice those videos with the Corolla in and upload them as one edited video to my channel? Will credit you in the description if you like.![]()
